Hi guys,
Our team is developing a Java application using ETA API to obtain and contribution information from TREP. I have been following the online guidance developing the consumer application and so far there's a concerning bug. Our application occasionally lost channel connection with TREP and we have to setup automatic recovering method to keep the market information live. The disconnect happens randomly, range from once a week to once a day. I have followed the following link's example to program the ping handler that will periodically check the channel status. I will assume the channel connection is bad if my ping action returns return code that's less than TransportReturnCodes.SUCCESS.
How can I trace down the root cause of this failing ping attempts? Is there something wrong with the client application / example code or the TREP ADS service?
Please help, and thank you for your time.
