We are trying to go over ETA Quick Start for Electron Java SDK. https://developers.refinitiv.com/en/api-catalog/refinitiv-real-time-opnsrc/rt-sdk-java/quick-start#eta-quick-start We have EZD 1.2 deployed. And we can telnet port 14002
When we try to run the command from the tutorial
./gradlew runVAConsumer -PcommandLineArgs=" -c localhost:14002 ELEKTRON_AD mp:AAPL.O"
We see an error like SocketChannel.read returned -1 (end-of-stream)
Could you please suggest what could be a problem ?
Logs:
Starting a Gradle Daemon (subsequent builds will be faster)
> Task :Eta:Applications:Examples:runVAConsumer Ultra Performance API (UPA), Java Edition, LibraryVersionInfo productVersion: 3.2.0.1 productInternalVersion: etaj3.2.0.L1.all.rrg productDate: Thomson Reuters Consumer initializing... Channel Up Event: java.nio.channels.SocketChannel[connected local=/127.0.0.1:61738 remote=localhost/127.0.0.1:14002] Connection down reconnecting: Channel java.nio.channels.SocketChannel[connected local=/127.0.0.1:61738 remote=localhost/127.0.0.1:14002] Error text: SocketChannel.read returned -1 (end-of-stream)
