I'm working through the ETA Java tutorials at https://developers.refinitiv.com/elektron/elektron-sdk-java/learning?content=43395&type=learning_material_item
I am able to establish a connection to my company TREP infrastructure, but getting an issue as it is defaulting to my user credentials.
Do you have any example code on how to provide DACS id, position, applicationId (in the context of the tutorial code) so that I can establish a session using the DACS id?
These are my logs:
basicConsumer initializing... Connection up! Registering our connection within our event loop Received Login StatusMsg State: Closed/Suspect/User unknown to permissioning system, it could be DACS, AAA or EED - text: "apankha, unknown to system." Connection down reconnecting Error text: SocketChannel.read returned -1 (end-of-stream) Connection up! Registering our connection within our event loop Received Login StatusMsg State: Closed/Suspect/User unknown to permissioning system, it could be DACS, AAA or EED - text: "apankha, unknown to system."
