When (if ever) would a DSS REST API client get http 201 or 3xx responses?
A question arose on some of the documented http response codes listed at a link from the DSS API here: https://hosted.datascopeapi.reuters.com/RestApi.Help/Home/StatusCodes. The questions was specifically on the 201 and the 3xx responses listed. There are valid http codes, but do they ever occur with DSS and if so under what circumstances?
11.3k 25 8 13
@mrr, One circumstance which I have found the status code 201 is creating Instrument List or Report Template. Please refer to REST API Reference Tree.
13.7k 26 8 12
@mrr,
For DSS I have personally never observed HTTP status codes 201 or 3xx. That does not mean it could not happen, but I cannot think of a case where it would.
For TRTH a 302 (redirect) will occur if you download the resulting data from AWS, as described in the article on boosting TRTH downloads with AWS.
Thank you both. I have confirmed that a 201 response code is sent when an instrumet list is created.
