Getting error 502 on Search/ReferenceHistory?
Hi
I come across an error 502 with a message notifying a server error:
cid:image003.jpg@01D576B7.72DC9890
The parameters of the query are as follow:
Could you please help?
Regards
Benoit
dss-rest-apidatascope-selectdsserror-502
13.7k 26 8 12
@bilou_12,
I have just tried your request, and I get a result (with HTTP status 200 ok).
DSS HTTP status codes are documented on this page. A 502 is a server error, more precisely: "The server, while acting as a gateway or proxy, received an invalid response from the upstream server it accessed in attempting to fulfill the request."
If the 502 occurred during the weekend, that could have been a maintenance period, in which case that would be normal.
Can you try again and see if you get the same error ?
Hi Christiaan
Agree with you, it is working again this morning.
Thanks for your help!
Benoit
