Hi, I've run into a problem requesting historical intraday data for non-current identifiers.
This code works fine for the current RIC WH0:
var extractionRequest = new TickHistoryIntradaySummariesExtractionRequest() { IdentifierList = new InstrumentIdentifierList() { InstrumentIdentifiers = new[] { new InstrumentIdentifier { Identifier = "WH0", IdentifierType = IdentifierType.Ric } } }, Condition = new TickHistoryIntradaySummariesCondition() { DaysAgo = null, MessageTimeStampIn = TickHistoryTimeOptions.GmtUtc, QueryEndDate = DateTime.UtcNow, QueryStartDate = DateTime.UtcNow - TimeSpan.FromYears(20), ReportDateRangeType = ReportDateRangeType.Range, ExtractBy = TickHistoryExtractByMode.Ric, SortBy = TickHistorySort.SingleByRic, DisplaySourceRIC = false, SummaryInterval = TickHistorySummaryInterval.FifteenMinutes, TimebarPersistence = true }, ContentFieldNames = new[] { "Close Ask", "Close Bid", "Volume", "Last" } }; extractionsContext.Options.AutomaticDecompression = true; //Decompress gzip to plain text var extractionResult = extractionsContext.ExtractRaw(extractionRequest);
When I then try to get data for historical RIC "WH3", the above code runs but returns no data.
I then tried changing to use "HistoricalInstrumentIdentifier" instead of "InstrumentIdentifier" (line 5), but I get this error:
"Cannot use a HistoricalInstrumentIdentifier when the ReportDateRangeType is not set to PerIdentifier.'"
So, as the error suggested, I changed to use ReportDateRangeType.PerIdentifier. However, I then get this error:
"ThomsonReuters.Dss.Api.ForbiddenException: 'Not authorized to perform extraction with ReportDateRangeType set to PerIdentifer.'"
I am able to request this data via the DSS web portal manually so I don't think I am unauthorized.
What do you suggest to get this working please?
