Wrong timestamp (LocalExchangeTime) in Intraday Summaries Extraction Request
I'm extracting tick data for certain RICs by posting appropriate Extraction Request with MessageTimeStampIn" : "LocalExchangeTime". The following is the Extraction Request
   "ExtractionRequest" : {
      "@odata.type" : "#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.TickHistoryIntradaySummariesExtractionRequest",
      "ContentFieldNames" : [
         "Close Ask",
         "Close Bid",
         "High",
         "High Ask",
         "High Bid",
         "Last",
         "Low",
         "Low Ask",
         "Low Bid",
         "No. Asks",
         "No. Bids",
         "No. Trades",
         "Open",
         "Open Ask",
         "Open Bid",
         "Volume"
      "IdentifierList" : {
         "@odata.type" : "#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.InstrumentIdentifierList",
         "InstrumentIdentifiers" : [
               "Identifier" : "AULM8",
               "IdentifierType" : "Ric"
         "ValidationOptions" : {
            "AllowHistoricalInstruments" : 1
         "UseUserPreferencesForValidationOptions" : 0
      "Condition" : {
         "MessageTimeStampIn" : "LocalExchangeTime",
         "ReportDateRangeType" : "Range",
         "QueryStartDate" : "2018-05-08T00:00:00Z",
         "QueryEndDate" : "2018-05-09T00:00:00Z",
         "SummaryInterval" : "OneMinute",
         "TimebarPersistence" : 1,
         "DisplaySourceRIC" : 1
Data is correctly returned. However, sometimes the timestamp is not in LocalExchangeTime for a row (for rest of the rows its correct). For example, see below
AULM8,,Market Price,2018-05-08T18:58:00.000000000-05,Intraday 1Min,.......
AULM8,,Market Price,2018-05-09T01:59:00.000000000+02,Intraday 1Min,.......
For AULM8, in the last row, although the value of the timestamp is correct, the Local Exchange timestamp should've been
2018-05-09T18:59:00.000000000-05 instead of 2018-05-09T01:59:00.000000000+02, since it's an US instrument.
Note: I've noticed this behavior in certain other instruments too (AULU8, FLGM8). Could you please check why the timestamp is not correctly returned in Local time sometimes?
Thanks!
dss-rest-apidatascope-selectdsshistoricaltime-stamp
23k 22 9 14
Hello @ggoli,
The fix was deployed. I run a test on my side, the result looks good. Could you please verify on your side as well?
Thanks,
-Zoya
Working now. Thanks for the fix!
23k 22 9 14
Hello @ggoli,
I was able to reproduce the issue you are seeing.
We have opened case #06570129 to investigate it on the content side.
Hi @ggoli ,
Not yet, but will keep posted here if any info
@zoya.farberov Okay. Thanks!
Hi @zoya.farberov, is there any update on this?
