DSS2Instruments.java and Bad Request
13.7k 26 8 12
@Oran, the syntax you use for the IdentifierType is not the same when you import a CSV manually using the GUI (ISN), and when you use the API (Isin). You need to change the following in your code:
"IdentifierType": "Isin"
The list of values for the API is documented here.
