DSS JAVA SAMPLES and KeyStore
@Oran
Thank you for your participation in the forum. Are any of the replies below satisfactory in resolving your query? If yes please click the 'Accept' text next to the reply that best answers your question. This will guide all community members who have a similar question. Otherwise please post again offering further insight into your question.
Thanks,
-AHS
C:\Program Files\Java\jre1.8.0_171\lib\security\cacerts
I have used C:\Program Files\Java\jdk1.8.0_131\jre\lib\security\cacerts and can run the Java example properly.
The issuer of hosted.datascopeapi.reuters.com is "CN=DigiCert SHA2 Secure Server CA, O=DigiCert Inc, C=US".
*** Certificate chain
chain [0] = [
  Version: V3
  Subject: CN=hosted.datascopeapi.reuters.com, O=Thomson Reuters, L=Eagan, ST=Minnesota, C=US
  Signature Algorithm: SHA256withRSA, OID = 1.2.840.113549.1.1.11
  public exponent: 65537
  Validity: [From: Fri Mar 02 07:00:00 ICT 2018,
               To: Fri Nov 01 19:00:00 ICT 2019]
  Issuer: CN=DigiCert SHA2 Secure Server CA, O=DigiCert Inc, C=US
  SerialNumber: [    023fc926 b2413d4f e1db3080 eeba72e6]
You can run the example with this JVM option: -Djavax.net.debug=all:handshake:verbose to verify the certificate chain.
If the application run through a proxy, you need to add a proxy certificate to the key store.
11.5k 16 7 10
Hello @oranjsr
You can follow the Building a keystore file to be used with an HTTPS (or ENCRYPTED) connection type for real-time Java-based APIs article to create a keystore file for your Java application.
