API request returns error invalid RIC for get_timeseries
The following code throws me an error. At the same time, Excel add-on returns a time-series for the same RIC and dates.
import eikon as ek
df = ek.get_timeseries("LLCCS30",
                       start_date="2018-06-01",
                       end_date="2018-06-10",
                       fields='CLOSE')
The error is the following:
Error with LLCCS30: Invalid RIC
LLCCS30: Invalid RIC |
Error code -1 | LLCCS30: Invalid RIC |
How should the error be handled?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonapi
18k 21 12 20
Hi @stephen.smirnov
I tried to use "LLCCS30" identifier but I could not retrieve data from Eikon Desktop nor Eikon Excel.
In this case, I believe that the LLCCS30 is not a valid RIC code.
11.5k 16 7 10
Hello @stephen.smirnov
I have checked the LLCCS30 item name with DataScope Select API and I cannot find this item as either a RIC code or ISIN code. It confirms chavalit investigation above that the the LLCCS30 is not a valid item name.
