Close price older than Oct 2017
Hi Is there a limitation on accessing data? I am trying to get a dataframe of Close prices for a list of companies. But no matter on the start date, saves only data from 18/10/2017. Do you know how can I access data from let's say last 10 yr?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonhistorical
23k 22 9 14
Hello @ecaterina.biris,
In addition to the answer by @James.Perkins about the content available,
you may find useful to refer to EIKON DATA API USAGE AND LIMITS GUIDELINE on the retrieval limits.
In terms of the specific limit that you appear to be hitting, 3000 max per single request, you may find this discussion to be useful and comprehensive, every answer providing additional details that are relevant.
The amount of history will depend on the interval you use as well. .. For daily closes generally around 10 years of data sounds about right. If you change the interval="weekly" ,, this will expand the historical universe... (and more for "quarterly").
Can you please tell me what is the limit: Apparently is a limit per query. If I use a list of stocks like 8-9 I receive as answer lower data than when I use just one stock. This limits me in scaling up get_timeseries; and I should use it in a loop.
