Field for ISO 2-alpha country code ?
Hi
Is there Field that can provide a ISO 2-alpha country code? In the dictionary that we have EMA seems to only provide a 3-alpha country code (CTRY_ISSUE FID 1652)
Also please confirm for FID 1652, the 3-alpha country code follows the ISO standard?
7.6k 15 6 9
I have checked the code in enumtype.def but I can't find Alpha-2 ISO code and it looks like content team use only Alpha-3 represent country code. Basically, the data spec and standard has been defined by the content team. I would suggest you open a ticket to content support using Get Support to confirm if we have any field which uses Alpha-2 ISO represent country code.
Thanks for verifying about the usage of Alpha-3 Country code. Ill check with content support for any 2-Alpha ISO country code they may have.
