Excessive memory usage when use rmtestBuffer.apply()
hello:
I found my memory useage increase quickly from 1% to 27% after I decode HKSE brokers use "rmtestBuffer.apply()"。
I develop with EMA C++ sdk 1.3.1;
when I decode HKSE brokers with RIC such as "0874bk.HKd", the num of RIC I requested is 14000+
and use "rmtestBuffer.apply()" to decode the updateMsg refer to "310MarketPriceRmtes";
my memory usage increase quickly.
memory usage do not decode brokers: 1%
memory usage do decode brokers: 27%
the detail info as "https://community.developers.refinitiv.com/questions/47273/ema-c-get-illegible-contents-in-updatemsg-of-broke.html"
@luxiangyuan
I think it is expected behavior when having a lot of thomsonreuters::ema::access::RmtesBuffer objects used to cache the RMTES strings.
0874bk.HKd is a page record which contains "ROW80_1" to "ROW80_13" fields which require RmtesBuffer to store the RMTES strings.
If you have a lot of page record RICs in 14000+ subscribed RICs, the application will require more memory in order to cache the strings.
