We are looking for a way to retrieve the current ILA permissions on our Edge via a TREP api like RFA or EMA ?
John Westi
John Westi
As far as I know, you should be able to use RFA or EMA to request "%CCONFIG" RIC from the Edge server using OMM MarketPrice domain. Not sure can you try one of EMA or RFA example to request the RIC?.
Below is the console output from EMA example 200__MarketPrice__Streaming when using with my TREP ADS server.
Item Name: %CCONFIG Service Name: API_ELEKTRON_EDGE_TOKYO Item State: Open / Ok / None / 'All is well' Name: PROD_PERM Value: 212 Name: RDNDISPLAY Value: 132 Name: DSPLY_NAME Value: blank Name: BOND_TYPE Value: Name: ROW64_1 Value: Product : Elektron Edge 2.5.6 B4 Name: ROW64_2 Value: Server Name : EDGETOKXXXX Name: ROW64_3 Value: Server ILA : #X3XXX Name: ROW64_4 Value: Server ID : ccab Name: ROW64_5 Value: Service : FTN Name: ROW64_6 Value: Field Def : 4.20.31 Name: ROW64_7 Value: Deployment Type : Feed Name: ROW64_8 Value: Platform : HP ProLiant DL360 G6 Name: ROW64_9 Value: Memory (MB) : 12276 Name: ROW64_10 Value: Current Connected Host : tk2p-XXXXXa Name: ROW64_11 Value: Max Server Watchlist Size: 750000 Name: ROW64_12 Value: blank Name: ROW64_13 Value: blank Name: ROW64_14 Value: blank Name: RECORDTYPE Value: 0 Name: REG_ID1 Value: 0 Name: REG_FIELD1 Value: blank Name: ROW1_TIME Value: blank Name: ROW2_TIME Value: blank Name: ROW3_TIME Value: blank Name: ROW4_TIME Value: blank Name: ROW5_TIME Value: blank Name: ROW6_TIME Value: blank Name: ROW7_TIME Value: blank Name: ROW8_TIME Value: blank Name: ROW9_TIME Value: blank Name: ROW10_TIME Value: blank Name: ROW11_TIME Value: blank Name: ROW12_TIME Value: blank Name: ROW13_TIME Value: blank Name: ROW14_TIME Value: blank Name: BYTE_BMAP Value: 0 Name: PREF_DISP Value: 0 Name: DSO_ID Value: 0
Anyway, if you found a status message about permission to request the RIC, you may need to contact the infra support team to verify the issue.
Hello @John.Westi
If your problem is not about permission to request the RIC mentioned by moragodkrit, I suggest you should contact Elektron Edge support team to ask for the way to get ILA permissions on your Edge. If there is a RIC providing this info, RFA or EMA should be able to used to get the info by subscribing the RIC. You can submit the query to Elektorn Edge support team via Get Support of MyRefinitiv and select Product to be Elektron Edge
Hope this help.
