Hi
Could you please indicate which condition to use to define the summary interval when using
TickHistoryIntradaySummariesExtractionRequest
I can't find it in the .NET example applications.
thanks and regards
Hi
thanks and regards
SummmaryInterval is defined in the TickHistoryIntradaySummariesCondition class. The possible values are:
public enum TickHistorySummaryInterval { OneSecond = 0, FiveSeconds = 1, OneMinute = 2, FiveMinutes = 3, TenMinutes = 4, FifteenMinutes = 5, OneHour = 6, }
The example is available in the C# Example Application at the download section. Please refer to the On Demand Extractions -> Create: TickHistoryIntradaySummaries example.
From my test, if it is not defined, it will return Intraday 1 Sec interval data.
