Is it possible for the API using Console application – Microsoft visual studio C# .NET instead of postman?
Hi!
We are trying to connect but we get back the login from the user. We would need to understand the JSON format that we would get and how to config in Microsof visual studio. We need to know the protocol.
We attach your examples we are bassed on (developers.refinitiv.com....\DownLoads\Code Examples\World-Check One API C# .NET Request Code Examples)
c.zip
Thanks in advance!
Regards
world-checkworld-check-onec#
c.zip (209.0 KiB)
4.5k 4 7 8
@jocarrasco,
Thank you for your query.
Yes, you can use Microsoft Visual Studio C# to develop your own solution. You can use postman to test the response received from the World-Check One API.
Can you please elaborate a bit more on - 'We are trying to connect but we get back the login from the user'? Are you getting any error?
Also, please let us know what information would you need in specific about the World-Check One API?
Thanks, but I have already developed my own solution. And it works great!
Can you please share your solution as I am looking for the same sample? need to fetch rates from Reuters using c# console application @jocarrasco
@sudith.divakaran,
Please refer to the below link and check the CODE EXAMPLE section for sample codes. Link - https://developers.refinitiv.com/en/api-catalog/customer-and-third-party-screening/world-check-one-api/downloads
Please note : This code is just a sample reference code. This may not work in your application.
