I am using WorldcheckOne Pilot and I want to screen different parties with different score threshold.
How can I change the score threshold from my application?
Thanks,
Thanks,
Hi @ziad.abourizk,
Thank you for the query.
The only way to change the score threshold is using the World-Check One UI (web interface). There is no other way to make changes in the score threshold.
Thank you for accepting the answer.
I would advice you to refer to the slider for checking the threshold and not the theshold score value, as if there are changes in the backend, there are chances that the set threshold score value may become outdated due to the changes made in the updated version.
