We are currently using the record replay tool provided by Reuters :
As described there are two formats for the record/replay :
- Xml
- Binary
In our side, the binary file is well replayed. However, we got some troubles with Xml file.
After some investigations we managed to make it works, but it requires to manually update the recorded Xml file.
So we think this is not something expected and this is why we would like to get your advises.
Our detailed test case :
- Prerequisites :
- Trrt : hostname where our Reuters server is deployed
- 14002 : the port to connect to the server
- Record
- Xml
rmdstestclient -S IDN_RDF -h trrt -p 14002-ct rssl -u r_msa -ef RIC.lst -rf 8-of idn_rdf.xml
- Binary
We followed the documentation :
- Replay
- Xml
./sink_driven_src -S IDN_RDF -Q idn_rdf.xml -U 1
-N 14001
-K -ik
- Binary
./sink_driven_src -S IDN_RDF -bdf idn_rdf.dat -U 1
-N 14001
-K -ik
- Final result :
- Xml
- i.We get this error :
./sink_driven_src -S IDN_RDF -bdf idn_rdf.dat -U 1-N 14001-K -ik Initialized RSSL library Failed: rsslEncodeFieldEntry ,return value = "RSSL_RET_UNSUPPORTED_DATA_TYPE: Failure: The data type is unsupported. (-24)"...
- ii.Finally after all the following modifications in the recorded file idn_rdf.xml (you will find attached the two files the original and the manually fixed one) : it works fine :
- Xml file reformatting
We noticed that the recorded Xml file is currently corrupted.
After some additional investigations, it seems that the root cause of this issue is the bad-formatted XML file generated from the "record" script.
Narrowing down to two eligible fields which might cause this, We have managed to replay successfully an XML file by changing the following :
- initially to be able to load the entire XML file without losing data, add the missing dataType="RSSL_DT_TIME" for fields between 13404 - 14208 under the XML element <refreshMsg domainType="RSSL_DMT_MARKET_PRICE".
- qosRate="2" ---> should be changed from 2 to 1 in all occurrences
- <mapEntry flags="0x0" action="RSSL_MPEA_ADD_ENTRY" key="257" > --->key should be changed from 257 to 1 under the XML element <refreshMsg domainType="RSSL_DMT_SOURCE"
- Binary
- i.It works fine
Is that expected ?
How can we record a correct Xml file ?
Thanks,
