Difference between "UseUserPreferencesForValidationOptions" and "ValidationOptions
What is difference between DSS API options "UseUserPreferencesForValidationOptions" and "ValidationOptions"?
These two seem to be the same, but please advise how different they are.
example:
"ValidationOptions": {
  "AllowOpenAccessInstruments": true,
  "AllowHistoricalInstruments": true,
  "AllowLimitedTermInstruments": true,
  "AllowInactiveInstruments": true,
  "AllowUnsupportedInstruments": true,
  "ExcludeFinrAsPricingSourceForBonds": true,
  "UseExchangeCodeInsteadOfLipper": true,
  "UseUsQuoteInsteadOfCanadian": true,
  "UseConsolidatedQuoteSourceForUsa": true,
  "UseConsolidatedQuoteSourceForCanada": true,
  "UseDebtOverEquity": true,
  "UseOtcPqSource": true,
  "AllowSubclassImport": true
"UseUserPreferencesForValidationOptions": false
Regards,
Hiroko
13.7k 26 8 12
@hiroko.goto,
Both these settings can be set in a data extraction request, to change the system behavior for that specific request. The purpose it to override the defaults defined in the general preferences set in the GUI.
ValidationOptions
Sets individual options. Each one of these overrides the equivalent setting defined in the general preferences.
Disables all user preferences. The behavior reverts to the default, but with all the overrides defined using ValidationOptions.
Please also note that the settings in the general preferences set in the GUI only apply to scheduled extractions, not On Demand extractions, which systematically use defaults. Hence the fact that these 2 parameters are often used in On Demand extractions, the most common use case being to retrieving data for historical instruments, by setting:
"ValidationOptions": { "AllowHistoricalInstruments": true },"UseUserPreferencesForValidationOptions": false
Hope this clarifies.
