Hi
Is it possible to search for expired equity options in DSS/DSS REST API?
It seems that they are not listed when I use https://hosted.datascopeapi.reuters.com/RestApi/v1/Search/FuturesAndOptionsSearch
Thank you
Hi
Thank you
I do not believe that it is possible to search for expired options.
I have just made a few tests to confirm that, and managed to get results with an expiry date of 24 May 2019, but nothing prior to that.
For the record, below is the body of the call I made, which returns no results. If you change the date to 24 May 2019 you will get results with an expiry date of 24 May 2019.
{ "SearchRequest": { "FileCodes": null, "CurrencyCodes": null, "ExchangeCodes": null, "StrikePrice": { "@odata.type": "#ThomsonReuters.Dss.Api.Search.NumericRangeComparison", "From": 1, "To": 10000 }, "ExpirationDate": { "@odata.type": "#ThomsonReuters.Dss.Api.Search.DateValueComparison", "ComparisonOperator": "LessThanEquals", "Value": "2019-05-23T00:00:00.000Z" }, "IdentifierType": "Ric", "Identifier": "ED*", "PreferredIdentifierType": "Ric", "UnderlyingRic": "ED" } }
Thank you. Is the data available if I manage to find the RIC in an other way or is the data not available in DSS?
it is possible to retrieve historical data using DSS, but you need to bear the following in mind:
Here is an example data retrieval for a future derivative that expired in September 2017:
{ "ExtractionRequest": { "@odata.type": "#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.PriceHistoryExtractionRequest", "ContentFieldNames": [ "RIC", "Trade Date", "Universal Close Price", "High Price", "Low Price", "Open Price", "Accumulated Volume Unscaled", "Bid Price", "Asset Type", "Quote ID" ], "IdentifierList": { "@odata.type": "#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.InstrumentIdentifierList", "InstrumentIdentifiers": [ { "Identifier": "STXXU7", "IdentifierType": "Ric" } ], "ValidationOptions": { "AllowHistoricalInstruments": true }, "UseUserPreferencesForValidationOptions": false }, "Condition": { "AdjustedPrices": true, "QueryStartDate": "2017-05-30T00:00:00.000Z", "QueryEndDate": "2017-05-31T00:00:00.000Z" } } }
It returns the following:
{ "@odata.context": "https://hosted.datascopeapi.reuters.com/RestApi/v1/$metadata#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.ExtractionResult", "Contents": [ { "IdentifierType": "Ric", "Identifier": "STXXU7", "RIC": "STXXU7", "Trade Date": "2017-05-30", "Universal Close Price": 3197, "High Price": 3203, "Low Price": 3203, "Open Price": 3203, "Accumulated Volume Unscaled": 5, "Bid Price": 3191, "Asset Type": "DERV", "Quote ID": "0x3000000000000000" }, { "IdentifierType": "Ric", "Identifier": "STXXU7", "RIC": "STXXU7", "Trade Date": "2017-05-31", "Universal Close Price": 3205, "High Price": 3215, "Low Price": 3215, "Open Price": 3215, "Accumulated Volume Unscaled": 5, "Bid Price": 3194, "Asset Type": "DERV", "Quote ID": "0x3000000000000000" } ], "Notes": [ ... ] }
Hope this helps.
Thank you @Christiaan Meihsl
What is the best way for me to extract historical equity option data for expired options?
Since I cannot search them, is there a way to re-build the RIC for such options? or another identifier?
Thnak you.
Apologies for the late response.
Q: What is the best way for me to extract historical equity option data for expired options?
A: As per my previous answer, using the validation options will do the trick for data requests. But note that validation options are not available for search queries, only for data extraction queries.
Q. Since I cannot search them, is there a way to re-build the RIC for such options? or another identifier?
A: Do you also have the TRTH product (it is a separate commercial offering from DSS, but uses the same servers) ? You should have it if you can access this link.
If yes you can use a historical search in the GUI or with the API (there are several API calls for historical searches).
If not, then I don't know how you could identify these RICs. That said, I'm not a data specialist. This forum is aimed at software developers using Refinitiv APIs. The moderators on this forum do not have the required deep expertise in all the content sets available through our products to answer your question. I advise you to call the Refinitiv Helpdesk number in your country. They will either have the answer for you right away, or will reach out to the content experts who can provide the answer you're looking for. As an alternative you can open a content-related enquiry via MyRefinitiv.
