2 Second Delay For Every Order
I am having a problem similar to some other users here, where each individual order takes 2 seconds to register on REDIPlus, i.e 10 orders takes 20 seconds. I have the REDIFix and I am using Submit2. From my analysis it seems that it takes REDIPlus 2 seconds to send me a confirmation message for each order. What are the fixes for this?
I am unsure if it is because I am running an old version of REDIPlus, so I have included my version below:
Version 16.1.0
File Version 11.0.123.40.40
Build 10:09:19 Aug 5 2016.
redi-api
23k 22 9 14
Hello @John and all,
The use of order.SetTFList have required additional processing time. Having commented it out, the processing time went down to the expected.
If it is necessary for the use case to SetTFList, then the processing will take longer.
To add some more detail I am connecting to your server in New York: 198.134.14.108.
I have been running latency tests to the two of the closest data centers to you, AWS and Microsoft Azure in Virginia, average 70ms for both.
