DSS REST API
Could you please provide the .NET code to specify a Schedule Relative Query when using the PriceHistory report. The .NETsample only provides date range example.
thanks
Ludovic
@ludovic.mesnier,
Schedules can be immediate, at a specific time of day, or triggered by data availability, as described in the API Reference Tree.
Can you please explain what you are trying to achieve ? I don't understand what "Schedule Relative Query" means.
11.3k 25 8 13
Hi @ludovic.mesnier
If you mean creating PriceHistory report template with Schedule Relative Query which is equivalent to the following Web UI, you can find sample code in this REST API Reference Tree.
The sample code is in the Request/Response Examples panel.
