"Settlement ability confirm" tag in Rediplus vba order entry code
Do you have the piece of Excel vba code that will check the “settlement ability confirmed” checkbox below:
Compatible with this piece of code:
hOrder.symbol = “6060.HK
hOrder.Exchange = “GSCC DMA”
hOrder.quantity = 100
so should probably be something like:
hOrder.settlementabilityconfirm = True
Obviously this example doesn’t work.
Any help would be appreciated.
Thanks!
redi-api
This particular field is supported for Japanese stocks only. It's required for some broker flows, so we recommend checking with your broker if these instructions are needed.
Hi @alexis.rementeria,
We're checking...will come back ASAP.
-Brian
Try:
hOrder.ShortVerbiage = 1
This is supported for Japanese equity short sells.
Once this is set, the Locate Broker and Locate fields in Message Monitor will be populated.
-Brian
Hi Brian,
Thanks, but that line of code does not work. We need to check that box for Hong Kong stocks but when I sent orders with it the box is not checked:
@zoya.farberov I spoke with @alexis.rementeria offline. I believe this is sorted out now.
