Hello @mjc,
Please check that you have, on your worksheet, defined column "N" and in the column, in every populated row, there are valid values that are being read.
One option is to, temporarily, remove all the rows, except for one and test your update to the Sun SendOrder with that single row. Once the updated Sub SendOrder works to your satisfaction, add the rows back.
Hello @mjc,
When you "view code" for Order Entry example, observe how Order object is populated in Sub SendOrder().
1. To your sheet add (as the last column) a new column for LocateBroker values, for example, column "N"
2. Absorb the value from the new column into your created Order as part of SendOrder sub:
Side = Worksheets("REDIEquityEntry").Cells(I, "E").Value Quantity = Worksheets("REDIEquityEntry").Cells(I, "F").Value ... LocateBroker = Worksheets("REDIEquityEntry").Cells(I, "N").Value ... hOrder.LocateBroker = LocateBroker
Does this work as you expect?
I did the above and i am getting a sub script out of range. the code for everything is below. I only added what you said before.
Sub SendOrder() Dim I As Integer Dim endRow As Integer endRow = GetLastRow("REDIEquityEntry", "G") For I = 3 To endRow ' Check if order was alread submitted Dim Exchange, Side, Quantity, Symbol, Price, PriceType, TIF, Account, Status, LocateBroker Side = Worksheets("REDIEquityEntry").Cells(I, "E").Value Quantity = Worksheets("REDIEquityEntry").Cells(I, "F").Value Symbol = UCase(Worksheets("REDIEquityEntry").Cells(I, "G").Value) Exchange = Worksheets("REDIEquityEntry").Cells(I, "H").Value PriceType = Worksheets("REDIEquityEntry").Cells(I, "I").Value Price = Worksheets("REDIEquityEntry").Cells(I, "J").Value TIF = Worksheets("REDIEquityEntry").Cells(I, "K").Value Account = Worksheets("REDIEquityEntry").Cells(I, "L").Value Status = Worksheets("REDIEquityEntry").Cells(I, "M").Value LocateBroker = Worksheets("REDIEqityEntry").Cells(I, "N").Value ' Check if doneaway trade can be entered Dim IsOrderGood As Boolean: IsOrderGood = True Dim MSG As String: MSG = "" Dim lvl As String: lvl = "" If Symbol = "" Then IsOrderGood = False: lvl = "ERROR": MSG = MSG & "missing Symbol." Exit For End If If Exchange = "" Then IsOrderGood = False: lvl = "ERROR": MSG = MSG & "missing Destination. " End If If Side = "" Then IsOrderGood = False: lvl = "ERROR": MSG = "missing Side. " End If If Quantity = "" Then IsOrderGood = False: lvl = "ERROR": MSG = MSG & "missing Quantity. " End If If PriceType = "" Then IsOrderGood = False: lvl = "ERROR": MSG = MSG & "missing Price. " ElseIf PriceType = "Limit" Then If Price = "" Then IsOrderGood = False: lvl = "ERROR": MSG = MSG & "missing Price. " End If End If If TIF = "" Then IsOrderGood = False: lvl = "ERROR": MSG = MSG & "missing TIF. " End If If Account = "" Then IsOrderGood = False: lvl = "ERROR": MSG = MSG & "missing Account. " End If If Not Status = "" Then IsOrderGood = False: lvl = "ERROR": MSG = MSG & "This trade was already submitted. " End If Debug.Print IsOrderGood & "--" & I If Not IsOrderGood = False Then Dim errMsg As Variant Dim rtnVal As Variant Dim ordInf As String Dim RetVal As Variant Dim RetVal1 As Variant Dim vName As Variant Dim vValue As Variant Dim vType As Variant Dim cnt As Variant Dim J As Integer Dim hOrder As New Order hOrder.Side = Side hOrder.Quantity = Quantity hOrder.Symbol = Symbol hOrder.Exchange = Exchange hOrder.PriceType = PriceType hOrder.Price = Price hOrder.TIF = TIF hOrder.Account = Account hOrder.Warning = False hOrder.Ticket = "Bypass" hOrder.LocateBroker = LocateBroker RetVal = hOrder.GetMBFieldCount(cnt) 'MsgBox cnt If cnt = 0 Then Worksheets("REDIEquityEntry").Cells(I, "N").Value = "No Additional Parameters required" Else For J = 0 To cnt - 1 RetVal = hOrder.GetMBFieldX(J, vName, vValue, vType) RetVal1 = hOrder.SetNewVariable("(MB) " + vName, CStr(Worksheets("REDIEquityEntry").Cells(I, 14 + J).Value)) Next J
