ek.set_app_key / name 'EikonError' is not defined
I've installed and imported the eikon library successfully and I was able to generate the Eikon Data API but then I tried running (with the my own key, not the one below)
ek.set_app_key(''8e5a3xxxxxxxxxxxxxxxxxxxxxxxxxxxx21b031c')
and I'm getting this error:
What should I do?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonapp-key
4.3k 2 4 5
This issue will be fixed with the next version (it should be published this end of month).
In the meantime, you can update Profile.py file in eikon library with following added line in import section:
from .eikonError import EikonError
Then, you should have the error message :
<Port number was not identified. Check if Eikon Desktop or Eikon API Proxy is running.>
That means eikon module didn't identify connection port number of Eikon Proxy.
=> did you start and connect Eikon successfully ?
How do I update the Profile.py?
If I just try running:
I get:
ModuleNotFoundError: No module named '__main__.eikonError'; '__main__' is not a package
in the command line, you can type ```pip show eikon``` it will give you the library physical location:
if you go to this location, you can open Profile.py in the code editor of your choice and add the missing line.
