Error code 400, reuters server unstable or my problem ?
File "/usr/local/lib/python3.5/dist-packages/eikon/json_requests.py", line 96, in send_json_request check_server_error(result) File "/usr/local/lib/python3.5/dist-packages/eikon/json_requests.py", line 144, in check_server_error raise EikonError(server_response['ErrorCode'], error_message) eikon.eikonError.EikonError: Error code 400 | Backend error. 400 Bad Request
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonerror-400
4.6k 26 7 22
@jonabl this error might be caused by the server not responding to your request on time, I suggest requesting a smaller set of data (less instruments or fields).
