Dear Community,
I created a C# application to receive data from TR Eikon via Eikon Data API. Here are the code lines:
IEikon eikon = Eikon.CreateDataAPI(); eikon.SetAppKey("3ed10c489c1d49c2b3cfbb45a2541e813b1112b1"); eikon.GetLoggerFactory().AddConsole(LogLevel.Debug); var x = eikon.GetDataRaw("USOILN=ECI", "ECI_ACT_DT");
In the first two hours, this worked perfectly. I could use the C# application. I could receive data directly from Eikon into my database. After a log out from Eikon I received the following error message:
{"ErrorCode":400,"Message":"BadRequest: Backend error. 400 Bad Request","Data"}
I searched for this Error Message and found out that in April Olivier DAVANT wrote "This ‘400 Bad Request’ error is a known issue that impacts several customers. Thomson Reuters development teams are working on a solution."
Could the development team already solve this problem?
This question is time critical.
Thanks for your help.
Christopher
Please find below the full error message
dbug: EikonDataAPI.DataGrid[0] UDF Request: {"Entity":{"E":"DataGrid","W":{"instruments":["USOILN=ECI"]," fields":[{"name":"ECI_ACT_DT"}]}},"ID":"123" } info: EikonDataAPI.Profile[0] Find port in a file: C:\Users\Administrator\AppData\Roaming\Thomson Reuter s\Eikon API Proxy\.portInUse info: EikonDataAPI.Profile[0] use port: 9000 info: EikonDataAPI.Profile[0] Return port: 9000 dbug: EikonDataAPI.DataGrid[0] UDF Response: {"ErrorCode":400,"ErrorMessage":"Backend error. 400 Bad Requ est"} fail: EikonDataAPI.DataGrid[0] {"ErrorCode":400,"Message":"BadRequest: Backend error. 400 Bad Request","D ata":{},"InnerException":null,"TargetSite":null,"StackTrace":null,"HelpLink":nul l,"Source":"JSONRequest","HResult":-2146233088}
