DACS webservice call to get Reports
At my work we're trying to automate our process for the quarterly Datafeed Access Declaration. To do this, I'm looking for a webservice call to fetch this report automatically (without connecting from a web browser). I've looked at the DACS webservice calls available, but I don't see anything that could help. Did I miss something?
For information, We're using DACS 7.3.
Pierre-Yves
DACSopen-dacsreport-template
23k 22 9 14
Hello @Pierre-Yves Rofes,
DACS WS API interface is mainly intended to efficiently manage DACS entities, for example, creating users and assigning entitlements, via API; to automate tasks that are commonly run in multiples and are repetitive via DACS UI.
I think, the closest to what you are looking for, reporting usage, will be getDacsRawUsageContents call.
Hello @zoya.farberov
Thanks for your answer. After i asked, I've seen this one, but when I try to run it, I get the following:
'aResult': { 'mResultText': 'FAILURE', 'mResultCode': 2096, 'mErrorText': 'The specified directory does not exist for the given site. (nothing to retrieve)' }, 'rawUsage': []
This is weird because when I generate the report and then download it from the web interface, it contains some data.
Note that the DACS instance on which I'm working is a dev instance so maybe it needs additional setup to be closer to our prod?
Thanks.
23k 22 9 14
This is not unexpected, as in order for dacs web service to provide raw usage info, on the local dacs, usage has to be stored in files. By default, I believe usage info is not stored in files on dacs, only in dacs db. So this is likely what you are observing.
