Host name resolved too often
Hi all,
we are using /Elektron-SDK1.2.2.linux.rrg/Cpp-C/Eta to post messages to TRCC.
Each time sending a message "rsslHostByName" is called from the eta-library
to resolve the IP adress of the local host - propably within
"rsslTunnelStreamSubmit".
That is quiet a performance issue. Can I turn that feature off?
And why is it necessary to call that function thousand times a second?
Yours
Thomas
elektronrefinitiv-realtimeelektron-sdkrrteta-apielektron-transport-apircc-api
23k 22 9 14
Hello @Thomas Wolf,
Just a double-check, have you copied the post encode from an example, are you sure you are not calling rsslHostByName from encode, in order to obtain the IP address, as the example does:
rsslHostByName(&hostNameBuf, &ipAddrUInt32);
postMsg.postUserInfo.postUserAddr = ipAddrUInt32;
Ups - I have overseen that completly!!
But good for me, for I can easily replace that call.
Sorry I have bothered you. And thanks for your attention.
