Please make sure that the application connecting to the right server/IP address.
If the problem persists please contact Refinitiv Account Team who provide you the server/IP.
Or you can submit a query to Technical Specialist team vi ContactUs and provide the message you receive and server/IP. The support team should be able to help you verify the issue.
thanks very much for your advice.
As far as we know, what we need is to pass username or Machine Account and password and connect to the right TRCC server. I'm not sure what is CAPI_ID.
-Have you tried passing Machine Account in the following format SP01881.<Machine Account>.TRCC.0 ?
What API are using EMA or ETA? and Is this C++ or Java? Have you tried your TRCC account with the example from the article and still get the error?
