How to use the backup of TREP in EmaConfig.xml
hello:
I develop with EMA in C++, and use EmaConfig.xml;
when I use "Consumer_1", I can get quote from TREP1;
when I use "Consumer_2", to test the backup between TREP1 & TREP2, I get the error :
Exception Type='OmmInvalidUsageException', Text='dictionary retrieval failed (timed out after waiting 45000 milliseconds) for TREP1:14002)'
I want to know how to use Consumer_2 to test the backup
We have two TREP, they are TREP1 & TREP1 as follows:
I have two consumer Consumer_1 & Consumer_2 shown as follows:
Hi @luxiangyuan
I can see from your screen capture that for Consumer_2 that your Logger and more importantly your Dictionary type is different to Consumer_1
Consumer_1 is using a Dictonary_1 which is set to ChannelDictionary in the default EMAConfig.xml file - i.e. download from server
Consumer_2 is set to use Dictionary_2 - which is set to FileDictionary in the default EMAConfig.xml
When you amend or use a Consumer_x definition, you need to ensure all values are configured correctly - not just the ChannelSet.
Therefore, if you wish to use download dictionaries then please ensure your Consumer_2 definition is set to use Dictionary_1 also.
Please read the EMAConfigGuide document as well as my EMA Config Overview article.
