Hi
[disclaimer: I am a beginner]
I need to import large samples of loans, for instance all loans issued in Europe since 1999 with all the loan variables available in Eikon
The deal screener has a limitation of 3000 loans
I would like to spare me many clicks on deal screener and hope for an excel solution, eventually a template like solution
I am puzzled by the universe function
After using dealscreener and obeying the 3000 constraint i select 1 country, exclude loans to financials & governments, and limit to loans after 01.01.2014; the resulting TFScreen.Deals is below
TFScreen.Deals(DEALSEXPRFORMAT(Deals,Active,1, IssuerStatus=Loans),curn=USD,(IN(TF.LO.BorrowNation(),"United Kingdom")=1),(NOT_IN(TF.LO.BorrowTRBCEcoSec(),"Financials","Governmental Services")=1),(TF.LO.CloseDate()>01/01/2014))
Then every item i want to pull for example:
TF.LO.LODealNo() TF.LO.Headline() TF.LO.Desc() TF.LO.Type() TF.LO.AnnDate() TF.LO.CloseDate() TF.LO.MaturityDate()
Uses this TFScreen.Deals
My idea is to try to automatize the extractions using the TFScreen.Deals, where 3 items would be changing: the borrower nation, the close date, and eventually the borrower sector)
The problem i have is that when i want to reference cells into the formula it doesn't work; i try to map somehow eikon templates i found (for M&A deals and so on)
For instance using such a formula:
'TFScreen.Deals(DEALSEXPRFORMAT(Deals,Active,1, IssuerStatus=Loans),curn=USD,((IN(TF.LO.BorrowNation(),"""&J4&""")=1)),((NOT_IN(TF.LO.BorrowTRBCEcoSec(),"Financials","Governmental Services")=1)),((TF.LO.CloseDate()>"&TEXTE(K4;"dd/mm/yyyy")&"))
where cell J4 has United Kingdom and K4 has 01/01/2014 doesn't work and i can't figure out why and what i am doing wrong
Thank you very much in advance for any help
Best
CG
