Using EZD with Websockets
I have tested the installation to verify that I can connect, similar to this page (It’s a docker instance of oracle 7, with the SSL ports exposed)
https://developers.refinitiv.com/en/article-catalog/article/how-test-elektron-websocket-connection-rmdstestclient-tool
However, when trying to run the python test examples with the EZD I run into a connection error. This can be seen in the screenshots I have attached.
When looking at the websocket api setup with TREP, it seems to be referring to ADS rather than EZD. As EZD setup is for SSL/RSSL is there something special I need to configure to open the port 15000. It seems like websocket quick start examples only use 15000
Any advice on how to move forward would be much appreciated!
refinitiv-realtimetreprdp-apiwebsocketsrrto
23k 22 9 14
Hello @laura11,
EZD does not support Elektron Websocket connections.
Please refer to the Websocket API Description:
"...Note: The Elektron WebSocket API supports both deployed TREP and Elektron Real Time in Cloud..."
Elektron WebSocket connectivity is supported by Elektron Realtime in Cloud and by Deployed TREP, version 3.2.1+
Please contact your Refinitiv Account team, to discuss the best option for you to move forward.
