Unable to process batch greater than 4358 rics
I'm getting following error when my batch input is > 4358 rics.
I'm using
//create OmmArray
OmmArray array;
array = EmaFactory.createOmmArray();
array.add(EmaFactory.createOmmArrayEntry().ascii(<RIC>)); // <RIC> - ric name
Using payload() function to send the array.
Exception Type='OmmInvalidUsageException', Text='Failed to rsslElementEntry.encode() while encoding rssl elementlist. Reason='INVALID_DATA'' at com.thomsonreuters.ema.access.CollectionDataImpl.ommIUExcept(Unknown Source) at com.thomsonreuters.ema.access.ElementListImpl.encodedData(Unknown Source) at com.thomsonreuters.ema.access.MsgImpl.msgPayload(Unknown Source) at com.thomsonreuters.ema.access.ReqMsgImpl.payload(Unknown Source)
23k 22 9 14
Hello @sagar.s.
I think you are hitting element array total size maximum, via batch.
Please refer to this question for the relevant discussion.
