Got null response with 200
X-Client-Session-Id: 645b1204-0508-11e9-be97-525400a87d41_951
I made a PriceHistory request, for 15 rics, and posted to
https://hosted.datascopeapi.reuters.com/RestApi/v1/Extractions/ExtractRaw
it responded with a 200 and I extracted the JobId: 0x0683f57ef6004360
I then made a request for that job id:
https://hosted.datascopeapi.reuters.com/RestApi/v1/Extractions/RawExtractionResults('0x0683f57ef6004360')/$value
But I received a response of http 200, but an empty response body.
I find if I make the request manually now, then I get a body like
{"@odata.context":"https://hosted.datascopeapi.reuters.com/RestApi/v1/$metadata#RawExtractionResults/$entity","JobId":"0x0683f57ef6004360"}
but that's no good if my system has already received a null response as if there was something wrong with the request.
Is this expected behaviour? I don't recall seeing it described as a danger in the documentation.
@davet1, could you please share the body of the original request ? That would help us analyse the issue.
I think I know why it went wrong.
The first response, despite being HTTP 200 said:
{"@odata.context":"https://hosted.datascopeapi.reuters.com/RestApi/v1/$metadata#RawExtractionResults/$entity","JobId":"0x0683f57ef6004360","Notes":["Extraction Services Version 12.3.40157 (ef2d4ecc8c9c), Built Jan  8 2019 20:56:33\r\nProcessing started at 2019-02-08 08:47:40.\r\nUser ID: 9019523\r\nExtraction ID: 2000000063525677\r\nSchedule: 0x0683f57ef6004360 (ID = 0x0000000000000000)\r\nSchedule dispatched via message queue (0x0683f57ef6004360)\r\nSchedule Time: 2019-02-08 08:47:39\r\nInput List (13 items):  (ID = 0x0683f57ef6004360) Created: 2019-02-08 08:47:40 Last Modified: 2019-02-08 08:47:40\r\nReport Template (5 fields): _OnD_0x0683f57ef6004360 (ID = 0x0683f57ef6204360) Created: 2019-02-08 08:47:39 Last Modified: 2019-02-08 08:47:39\r\nERROR: Extraction 0x0683f57ef6004360 failed because: 9019523 has 2 ET2 extractions, limit is 2\r\n"]}
I previously reported this and it was supposed to be fixed in January:
https://community.developers.refinitiv.com/questions/36550/request-limit-seems-to-return-200-not-429.html
@davet1, that looks like the explanation; it is good you found it, and thank you for sharing it.
But this is terrible. Why is it reporting 200? This was supposed to be fixed.
What am I supposed to do? Examine the string in the message because the system doesn't report 429 reliably?
@davet1,
I have asked the development team for an updated bug fix date.
In the meantime, even if it is not ideal, there are a few possible workarounds:
  • Managing requests to ensure that only 1 Price History request is sent at any time.
  • Parsing extraction notes to find issues. This is actually a recommended best practice, there is an article on this topic here.
Body of original request:
{"ExtractionRequest":{"@odata.type":"#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.PriceHistoryExtractionRequest","ContentFieldNames":["RIC","High Price","Low Price","Universal Close Price","Trade Date"],"IdentifierList":{"@odata.type":"#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.InstrumentIdentifierList","InstrumentIdentifiers":[{"Identifier":"000030.KS","IdentifierType":"Ric"},{"Identifier":"000120.KS","IdentifierType":"Ric"},{"Identifier":"000150.KS","IdentifierType":"Ric"},{"Identifier":"000210.KS","IdentifierType":"Ric"},{"Identifier":"000230.KS","IdentifierType":"Ric"},{"Identifier":"000240.KS","IdentifierType":"Ric"},{"Identifier":"000270.KS","IdentifierType":"Ric"},{"Identifier":"000640.KS","IdentifierType":"Ric"},{"Identifier":"000660.KS","IdentifierType":"Ric"},{"Identifier":"000670.KS","IdentifierType":"Ric"},{"Identifier":"000880.KS","IdentifierType":"Ric"},{"Identifier":"005380.KS","IdentifierType":"Ric"},{"Identifier":"005740.KS","IdentifierType":"Ric"}]},"Condition":{"AdjustedPrices":true,"QueryStartDate":"1999-02-08T08:47:38.353Z","QueryEndDate":"2019-02-08T08:47:38.353Z"}}}
13.7k 26 8 12
@davet1,
I have just successfully tested your request, in Postman, in the same manner as you describe:
What you observe is not expected behavior.
Note that a bad request would generate an error response with HTTP status 400, but here that is not the case, and I tested your request, it is fine.
Let us try to find the cause ...
1. One-off. It's not what I normally see with this particular workflow. But, I haven't made a huge number of requests, so this isn't one in a million.
2. Using my own code. The same code worked on previous requests and subsequent requests. In fact, I twiddled the state of the request in my application to let it reprocess and it received the expected response.
3. It replies appropriately:
@davet1,
3. That is not what it should reply, that call should deliver the data.
I will escalate this to the product support team to investigate what happened, using the Client-Session-Id you gave us, and keep you informed
