API Proxy not starting on Mac
The API proxy is no longer working. Reinstalled it and that did not solve the problem.
Currently getting a message that an unexpected error occurred:
Error Code: 101
Error message: [IPCBus:Broker] error = [IPCBus:Node]
error = timeout (2000ms) on {"port":"49152"}
This error is occurring before login.
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonapierror
@stephan would you please provide the logs? It can be location under ```~/Library/Application Support/Eikon API Proxy```
eikon-api-logs.zip
The logs are in the attached zip file.
eikon-api-logs.zip (19.6 KiB)
@stephan thank you, I have reported the issue to the dev
4.6k 26 7 22
Just to have a valid solution for this issue on a separate post, Mac restart helped to resolve the issue.
4.6k 26 7 22
@stephan, let's try and force the proxy app to use a different port. Open your Terminal app and run this:
/Applications/Eikon\ API\ Proxy.app/Contents/MacOS/Eikon\ API\ Proxy --busPort=49153
does it work?
Unfortunately not. Getting the same error as before and the following response in the terminal:
Unfortunately not. Still getting the same error message and the following in the terminal:
@stephan thank you, we are investigating.
@stephan could we check if anything is running on 49153 or 49152 on your machine? Here is the bash command:
lsof -i :49153
Ran the command with 49153 and also 49152. There was no response or something in the terminal to either commands. Do you see anything on your end?
@stephan, if you do not see anything, there is not a process that is using either of those two ports. A bit of a silly suggestion, but could you try restarting you Mac?
