REDI API cancel order by OrderRefKey
I have the following code but it throws type mismatch.
object err = null;
rediCache.Submit("Message", "Status==0 || Status==1 || Status==2 || Status==3", ref err);
rediCache.CancelByKey(redi_user_id, "gS01568314", ref err);
System.Runtime.InteropServices.COMException: 'Type mismatch. (Exception from HRESULT: 0x80020005 (DISP_E_TYPEMISMATCH))'
Could you also explain whether .submt() is necessary and what those status denotes?
Additionally, is there anything I must do when stopping application? Sometimes I noticed REDI hangs after I abruptly terminate redi api application.
Thank you!
apiredi-apiorder
@39783854-26aa-4fea-bc93-00b2ec21f8bb
I got the same exception if CancelByKey is called immediately after Submit. It works fine if I call CancelByKey in the CacheEvent handler.
However, from my test, the CancelByKey can be called without Submit.
object err = null;
The meanings of status codes and where options are mentioned in Appendix A REDI Data Fields in the REDI API SPECIFICATION.
 '======= REDI ORDER STATUS TABLE (status) =============
 ' 0: Open  1: Partial  2: Complete 3: Canceled 4: Reject
 ' 5: Deleted  6: Failed  7: Pending Reroute 8: Pending
For the hang issue, we need more information. Could you please share the application and steps to replicate the problem?
it worked with just submit as you had stated.
I got the example from REDI API pdf
1.10 Order Cancellation
Cancelling an Order By ‘OrderRefKey
Public WithEvents OrderQuery As CacheControl
Sub CancelOrder() Set OrderQuery = New CacheControl
Dim verr, table, where
table = “Message”
where = “Status==0 || Status==1 || Status==2 || Status==3”
OrderQuery.Submit table, where, verr
‘ Cancel Order
OrderQuery.CancelByKey “parkmm”, “YSJ1069332”, verr End Sub
table = “Message”
‘ Cancel Order
table = “Message”
‘ Cancel Order
