PyDSWS - get_data() - is there a way to download from earliest until end date given a ticker and field?
I'm have a script to download a few ticker with a field. However, not all the tickes have the same start date as some start earlier than others. Is there a way to request for the earliest until the specified end_date using the get_data() or any other api call? I'm using PyDSWS.
Thanks.
datastream-apidsws-api
Hi, Unfortunately there isn't away in which the system could determine the earliest history from a list of tickers. The datatype BDATE would need to be run on your list initially to ascertain the start date.
@James.Bright1
Is there a full documentation for DataStream Web Service REST APIs parameter for http requests for bypassing the PyDSWS entirely and writing a customized request? Thanks.
Hi, You can access the web service directly. More details can be found on the test harness.
http://product.datastream.com/DswsClient/Docs/Default.aspx
