Does EMA for Java can be run using OpenJDK? There is no clear statement in compartibility matrix on which JVM is supported (OracleJDK, OpenJDK).
Hi @bulanych,
The compatibility matrix outlines support for Java only. OpenJDK is not officially supported. If you choose to use OpenJDK and run into an issue, the issue must be reproduced with a supported version of Java.
Hope this helps.
