HIBOR Fixing Date/Time
Hi @thomson.reuters,
I have got enumtype.def on hand, which verison is 4.20.34.
I would like to fetch HIBOR Fixing Date/Time from TREP APIs, but I am not sure if such info could be found under section YRLO_IND 1076 data field.
Would you mind give me hints on it? Thanks a lot.
elektronrefinitiv-realtimetrep
4.4k 10 6 9
Hi
You should be able to fetch the date and time of HIBOR from VALUE_DT1 (875) and VALUE_TS1 (1010).
But please note that the <HIBOR=> RIC is a chain RIC. You will have to request the chain elements to get the rate and date/time.
