[EMA Java] How to retrieve the client id in OmmConsumerClient.onStatusMsg
the method OmmConsumer.registerClient returns a long value (id) that can be used later to unregister, etc. Can this value be retrieved from either the statusMessage or event received in OmmConsumerClient.onStatusMsg(StatusMsg msg, OmmConsumerEvent event) ?
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apijavaconsumer
hi @andre.malenfant
You can get the handle from the OmmConsumerEvent using
event.handle();
in the onStatusMsg Callback.
Note that if the StreamState of the item is already CLOSED when you receive the StatusMsg then you do not need to call unregisterClient - as the stream has already been closed off.
