Do you have an example on how to use : " rtmesBuffer" ? RMTES Decoder EMA provides a built in RMTES decoder. If desired, application may cache RmtesBuffer objects and apply all the received changes to them
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apijavaconsumer
9.5k 10 5 7
This is Elektron SDK Java bug in RmtesBuffer.apply(..) method. The bug has been fixed in version 1.1.0. The fixed package can be downloaded at Downloads page of Elektron SDK Java
Have you checked out the example 310 MarketPriceRmtes?
C+ folder: Ema\Examples\Training\Consumer\300_Series_Examples\310__MarketPrice__Rmtes?
Java folder:
Ema\Src\examples\java\com\thomsonreuters\ema\examples\training\consumer\series300\example310__MarketPrice__Rmtes
It extracts a RMTES_STRING type field and applies it to a RmtesBuffer.
Hope that helps.
9.5k 10 5 7
Hello @arnaud.mazzucco
EMA Java provides example310__MarketPrice__Rmtes application located in <Elektron SDK Java pakckage>\Ema\Src\examples\java\com\thomsonreuters\ema\examples\training\consumer\series300\example310__MarketPrice__Rmtes. The application showcases processing of RWF RMTES_STRING data type by using RmtesBuffer interface.
The example of the application's output:
Received Update. Item Handle: 1 Closure: 0
Item Name: N2_UBMS
Service Name: API_ELEKTRON_EPD_RSSL
Fid: 264 Name = BCAST_TEXT DataType: Rmtes Value: 株式会社エスプール: 平成29年11月期  第1四半期決算短信〔日本基準〕(連結) (Completed):  <2471.T>
Item Name: N2_UBMS
Fid: 264 Name = BCAST_TEXT DataType: Rmtes Value: DJ Eurex Interest Rates Futures Hourly Price Update
For more details of RmtesBuffer interface, please refer to <Elektron SDK Java pakckage>\Ema\Docs\refman\emajava\com\thomsonreuters\ema\access\RmtesBuffer.html
For instance I am trying to use rmtes buffer for ric : 66380bk.HKd on ELEKTRON_DD :
This is what I receive from the refreshMsg :
fid="316"name="ROW80_2"dataType="Rmtes"value=" BID ASK fid="317"name="ROW80_3"dataType="Rmtes"value=" 9705 -5s | 9705 fid="318"name="ROW80_4"dataType="Rmtes"value=" -1s 9053 | +1s fid="319"name="ROW80_5"dataType="Rmtes"value=" 9705 9705 | 9705 fid="320"name="ROW80_6"dataType="Rmtes"value=" 2310 | +2s fid="321"name="ROW80_7"dataType="Rmtes"value=" -2s | fid="322"name="ROW80_8"dataType="Rmtes"value=" | +3s fid="323"name="ROW80_9"dataType="Rmtes"value=" -3s | fid="324"name="ROW80_10"dataType="Rmtes"value="" | +4s fid="325"name="ROW80_11"dataType="Rmtes"value="" -4s | 9705 fid="326"name="ROW80_12"dataType="Rmtes"value="" 8130 |
But the updateMsg is like this :
fid="319" name="ROW80_5" dataType="Rmtes" value="69705"
It means that I don't receive a filed update, just a few characters => I can't rebuild the field and check what has been updated.
Do you have a solution for this Kind of issue ? The buffer does not work for that, ot the usage you show in the example does not address my issue.
Thansk a lot
Please see my response in the email.
Hi @arnaud.mazzucco
So, just to be clear - are you maintaining a unique instance of RmtesBuffer for each Field (for each RIC if consuming multiple RICs) and then using apply() method to update the corresponding instance of the RmtesBuffer as and when an update arrives for that particular field (for that RIC)?
And once you apply() the update, you then extract the string from the RmtesBuffer to get the full field for display purposes?
Yes, exactly!
Hi @arnaud.mazzucco
I understand my colleague has been in contact with you directly.
Just to confirm that this appears to be an issue with EMA Java and a fix request has been raised.
Regards,
Umer
