Is this a test system ? Are my permissions always the same, regardless of the environment I would be (assuming I am now accessing a test system) ?
@bernard.thouin, this URL corresponds to the production system, not a test system. What other environments are you referring to ?
I basically did not know how TR is handling things when a new user comes. Bloomberg offered for example a test environment to play in before moving matured software access to production systems. As a newbie to TR, I did not know if I had access to prod or to some other environment, hence my question. Your answer answers all my questions, as this means the user I am using has prod permissions :)
