Does not return calc dates when more than one ric in request get_data
Next code does not return calc dates for ric PLD.N^F11:
But in this code works fine (same code, but only for one ric 'PLD.N^F11'):
This is an error? How to check or solve? Thanks.
Raw code:
rics = ['PLD.N^F11', 'C.N',]
fields = ['TR.PtoEPSMeanEst.calcdate', 'TR.PtoEPSMeanEst.value']
params = {'SDate': '1994-01-01', 'EDate': '2018-10-31', 'Frq': 'AM', 'Period': 'FY1'}
info, err = ek.get_data(rics, fields, params)
info
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonerrordate
4.6k 26 7 22
@oalexandere the data comes back in this format from the backend, I will raise it with the product manager for the API. For this specific case, I would recommend doing separate requests for each share and then merging the data frames.
