[EMA C++] Is there any data dictionary for chain field
I develop with EMA C++,and decode the chain, I want to konow the data type of the chain field
I can get the Field 804;
I can not decode the Field 239.
which shows as the pic.
So, I want to get the data dictionary of chain Field, which will show the ditail of every Field
7.6k 15 6 9
@luxiangyuan
You can find field definition for any field from file RDMFieldDictionary locates under a folder named "etc" from EMA package. REF_Count use UInt64 according to the Dict so that you have to use fe.getUint() to get the data accordingly.
Consumer example such as 200__MarketPrice__Streaming also provide sample codes to get the data accroding to data type returned by fe.getLoadType().
Hi moragodkrit·
Thank you very much, it works;
I think I can resolve such problem for the future
