How to build Elektron-SDK1.2.2.java
Hello:
  1. I download "Elektron-SDK1.2.2.java.zip", and build it follows the guide show below:" "https://developers.refinitiv.com/en/api-catalog/refinitiv-real-time-opnsrc/rt-sdk-java/quick-start#rtsdk-build-system""
  2. I only run a cmd "gradlew Ema:Examples:tasks --all"
  3. I get errors as follows:
9.5k 10 5 7
Hello @luxiangyuan
When I uncomment “to enable …” and “jvmArgs…” line in Elektron-SDK1.2.2.java.rrg\Java\Ema\Examples\build.gradle file as shown below:
tasks.withType ( JavaExec ) {
	to enable the logger comment out the line below
	jvmArgs += "-Djava.util.logging.config.file=../Core/src/main/resources/logging.properties"
Then, I get the same problem as you
The reason is “to enable …” line is not the code that gradlew can run. It is the real comment.
After I change build.gandle file to comment “to enable …” line as shown below:
	//to enable the logger comment out the line below
Then I can run gradlew Ema:Examples:tasks -all successfully:
Hope this help.
Hi Pimchaya.Wongrukun
Thank you very much, it works
