Is there any "EMA Chain objects" realized in C++
Hi:
We develop with EMA(C++)。
now I want to get the "chains" of HKSE,
I only find the "JAVA Edition", but I have difficulty to understand it.
"https://developers.refinitiv.com/en/article-catalog/article/simple-chain-objects-ema-part-1"
Is there "C++ Edition" realize the "chains data".
thanks a lot.
23k 22 9 14
Hello @luxiangyuan,
The article you are looking at is in 2 parts:
simple-chain-objects-ema-part-2
The first part explains the concept of chain, how it is structured, and goes over the features that will be important for chain processing, that will apply in C++, Java, Websockets.
The second part gives an example of implementation of the concepts discussed in the first part, in Java.
There is, currently, no such example in C++. Nor in Websockets. The reader will be able to use the knowledge of the concepts to design a custom implementation, per their requirements.
Hi Farberov
Thanks for your answer.
