Error E0014 cannot conect to elektron sdk 1.2
Does anyone know what this error mean? I got from ezd.log
The EZD process has intercepted a login response failure to the client from host amers1.streaming-ec.cp.thomsonreuters.com on socket 10. Reason from source:Invalid ILA login(E0014)
Logging out client ipcSession.232 on socket 6 from source 127.0.0.1. Removing secure channel socketId 10. Reason from client: rsslRead() failed with code -1 and system error 0. Text: <Impl/ripcsrvr.c:6966> Error:1002 ripcRead() failure. Connection reset by peer
elektronrefinitiv-realtimeelektron-sdkauthentication
7.6k 15 6 9
@rmyers
Message Invalid ILA login(E0014) seems to be a problem between EZD and headend. I suggest you contact EZD support directly.
You can open a new support case to the team using MyRefinitiv and go to Get Support page and then choosing product Thomson Reuters Elektron Connect. The support team should be able to help you verify the setup.
