Correct authHostname url to be used
Hi team,
We are seeing that in all the documentation for the Elektron APIs and the Elektron Data platform the url for EDP Gateway is : api.refinitiv.com but in all the streaming examples given in the documentation and in the downloaded ones, the url is : api.edp.thomsonreuters.com.
Which is the correct one that we should use in our application?
Thank you
elektronrefinitiv-realtimeelektron-sdkwebsocketsauthentication
Hi @bansalshah, The correct URL is api.refinitiv.com - please use the streaming example with this endpoint. I will get the sample and documentation updated.
