connect spreadsheet to API
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonexcel
@neha.gupta1, could you give more detail on your query, what are you trying to achieve ?
Hi @neha.gupta1,
From what I understand, you're looking to send orders for equity orders, correct?
If so, this is the standard starter Excel sheet for order entry. The SendOrders macro is responsible for order entry.
Let us know if you need more info...hope this helps.
-Brian
I have already develop a algo in Eikon spread sheet. I want the order to automatically flow from spreadsheet to my broker account
@neha.gupta1
I'm afraid it's still not clear if there's a question you wanted to ask the community on this forum and, if yes, then what the question is. If you're looking for documentation on how to submit orders using REDI API, then the section on REDI on this portal has a tutorial for that. If you're looking for something else, then please provide a detailed description of what you're looking to do, what Refinitiv products you're using and what specific questions you'd like the community to answer for you.
